Coki
Forero Experto
- Ubicación
- Palmeralandia
- Pro Ceed 1.6 CRDI Active + Fox Racing R6 17'' + Muelles Eibach
Mmmmm .....
prueba a ver a dejarlo desconectadospuki dijo:Al dejarme sin navegador he visto el cable que va al freno de mano, el que impide ver dvd´s en marcha.
¿pasaría algo si lo corto directamente para inutilizarlo?, aver si algún entendido me aclara el tema.
This Pitstop addresses a concern on some 2006 and later Sedona (VQ), which may exhibit a discharged battery due to excessive intermittent parasitic electrical draw. In some cases the door lock key switch located on the back of both the driver’s and passenger's front door lock cylinders may not have been properly installed, may have come loose, or possibly was not reinstalled properly during a previous unrelated repair. As mentioned, this parasitic draw may be intermittent, as the switch by itself has no detent center position and is free to rotate (turn ON and OFF in either lock or unlock positions) if not attached properly to the door lock cylinder.
If a 2006 or later Sedona (VQ) has a discharged battery and a parasitic draw is present, first check the operation of the key switches using the GDS Scan Tool. If either key switch displays ON regardless of actual key position, this is the parasitic draw and the switch may not be fully installed. If the battery is discharged for no apparent reason, and no other symptoms exist, then an intermittent concern may exist. In this case please check both door lock key switches, assuring that the switches are properly installed.
Pues si eso es cierto es para cagarse.. 0,4 amperios en parado es una burrada, una batería gorda de un diésel, pongamos una de 100Ah y con esta formula que no es exacta pero si aproximada. 100/0,4=250 horas la batería a 0 patatero, pero en realidad mucha antes de eso ya no arrancaría el coche, si calculamos la mitad, saldrían 125 horas que traducido a día son cinco con algunas horas.spuki dijo:Me comentan en el taller que si los consumos del coche no superan los 0,4 en parado tienen orden de no hacer nada (lo consideran normal por el tema de memorias etc)
