Tema referente a los 2DIN (GPS, configuraciones, instalacion, etc...)
and seccond question :-) do you have a link for a "mount" around a radio? I have a spare there now and it isn´t pretty :( thanks[/QUOTE]
"mount" the radio is very easy.talk to er_nene and question 1 i can't help you
@cambreta
As I wrote I have already radio in my car but I have a spare around a radio. I need something like this Connects 2 CT23KI05A - KIA Ceed, Pro Ceed, Ceed SW 2007> Double Din Facia Plates do you have a link for which you have in your car?
and that 1. question: I need only translate to english or czech (if somebody speak :-) ) how i can connect it. i don´t understand that pictures on 1. page of this topic.
ABOUT FACIA PANEL:
Hello, there is no Facia panel to adapt this model (cerato) to Ceed, because the existent Facia panels are to adapt the standard 2din RadioCD to a Ceed Hole (not to adapt this RadioCD-Cerato model of 2din for the Ceed ¿ok?)
You must do it yourself by cutting, for example, this facia panel:
Autoleads FP-03-13 - Kia Ceed, Pro Ceed Car CD Stereo Fascia Trim Panel
You can do it with a dremel or something like that:
Dremel - Tools
Or you could buy epoxy resin, and fill the holes... and paint it:
Epoxy - Wikipedia, the free encyclopedia
ABOUT STEERING WHEEL:
You must change only one PIN of the connector READ IT:
https://www.kiafaq.com/car-audio-na...onfiguraciones-instalacion-etc.html#post98674
thanks for answer!
so that facia panel: ok I try it but I fear that it will not be a pretty... :-(
and that PIN: I already studied that picture but I don´t understand. Have I move that 2 UNMARKED PIN on that white and black position (beside)? Or I have to move that two MARKED (white and black on left upper side) PINs on that unmarked white and black positions? I hope that you understand me :-)
and If I can have last question: That upper displey (over radio = clock, pc info,...) Does it works with that gps (like exactly playing tracks)? THANKS
thanks for answer!
Hello, the answers:
how I can connect that steering wheel? Check the image on the post, only change the position of 2 wires: if (actually) the cables are in position a1 a2, change it to the other! XD Sorry, test it. I think that marked positions are correct (not where the cables are...)
I think the correct is: Have I move that 2 UNMARKED PIN on that white and black position (beside)?
Does the upper display works with that radio? NO more than now. Only temperature and info about fuel consumption etc
jaajajj podriais poner todo subtituladooo que en ingles soy nulo!! xD
Pues preguntaba por qué 2cables tiene que mover para los mandos del volante, si lo adecuado es dejarlos donde aparecen en la foto, o ponerlos en los 2 círculos...
Por otro lado dice que si sólo funciona la temp y el consumo en el cuadro principal, yo creo que sí, ya es bastante...
thanks for answer!
Hi, You can see the picture in post #18 of Cartujero, you must move the pins of yellow circle to the black and white positiones near them. It is possible that you have to move only one of them. Good Luck.
Ey, hace tiempo que no me meto ya que he estado en Madrid currando un tiempo y venia de vez en cuando pero tampoco como para quedar y al pobre Tidus lo he tenido descuidao, sorry, pero bueno ya he vuelto y para quedarme, o eso creo... jajaja.
Bueno, al grano, lo que queria saber es si alguien de Catalunya me ayudaría a poner la radio de sso ya que no me atrevo ni a sacar la controla central, jajaja. Y si me recomendais comprar las antenas amplificadoras que vienen opcionales... Muchas gracias y a la proxima quedada me apunto eh!!! aunque veo que esta la habeis hecho hace nada...
Hola a todos, el tema de la antena creo que esta pendiente. Alguien ha probado algo que funcione mejor que la que venia con el pedido original? Saludos a todos, ah, me refiero a tv, la del gps muy bien.
Hola!
Creo que este el post donde tengo que preguntar sobre esto...
Estoy pensando en ponerle una radio con GPS a mi pro_cee'd solo he mirado la que ofertan en la propia Kia por internet y no pone precio. Queria saber si alguien sabe el precio de que te lo instalen en un taller oficial (que me fio mas)o de algun modelo especifico de este tipo de radio y donde instalarla que yo no me atrevo hacerlo solo...
Gracias!!!
Hola chicos perdon si no encontre el tema pero queria saber donde habeis puesto la antenna del GPS ?
Yo la antena la he puesto dentro de la guantera...aproveche cuando desmonte la radio y la deje dentro bien cojida para que no se me soltara. Te coje señal sin problemas... la puedes poner en cualquier sitio siempre y cuando no tengas nada metálico por encima de la antena GPS porque parece ser que se quita la recepción.
Es porque cuando le pongo el prog se pone pero no da satellite ni nada :(
xenofron la mia esta pegada con el iman a un lado de la radio.NUNCA me ha fallado la señal por ahora.siempre a tope o - 1 rayita
Bueno ahora mi probleme es que no llego a poner los mandos del volante y el USB como se conecta todo eso? es porque no entiendo con lo que e visto en el tema :(
pues es colocar los pines que te marca un agujerito mas hacia un lado si no recuedo mal..y luego configurarlos desde ajustes...y lo del usb es un brico que tengo pendiente pero me da pereza
No veo lo que quereis decir y es que mi español lo estoy perdiendo un poco. ya que hace Dos años que ya no voy :S
Dime donde va cada uno de los pines y ya voy a ver.
